Why when i plug my outside antenna It cuts all my p25 channels out they will not work ?
On the outdoor antenna, you may be receiving more than one tower.Why when i plug my outside antenna It cuts all my p25 channels out they will not work ?
agreed. This may be a situation where more antenna is not necessarily more better. If your factory attenna worked, and you heard what you wanted, don't change.Using a outside Antenna would let the Prison overload the scanner frontend the only thing is to use a tunable trap to to block the Prison but that would also block Starcom and MoWins signals. Like posted above your best bet may just be use the Factory Antenna.
