Why would an icom A220 radio NOT tranmit if NOT fitted in a case?
nsdq160th
We are attempting to have an icom A-220 radio transmit outside of it's casing. I would just NOT transmit if not slid into the case. All other functionalities work. We attempted to contact icom service tech support via email but have not been getting a response back.
any one with any ideas??
devicelab
Radio N.E.R.D
WA (USA)
I took a look at an A200 service manual and there's nothing obvious shown that should prevent transmission while it's outside the case. It's easily found via a Google search. I couldn't find the A220 version specifically. You might want to glance at it yourself and see if there's anything you can see. The power requirement is 13.2v @ 2A so you may want to start there.
I had a random thought that if the antenna connection wasn't 100% stable then the transceiver might have a protection circuit if it detects reflected RF.
hazrat8990
Wyoming
Check where all of the screws mount. My thoughts are there is some sort of ground path that gets completed via the case.
nsdq160th
Hey, Hey, Hey!!! Turns out this pin 9 that affects the Transmit PTT was out of whack on this connector that was causing the issue. Nothing to do with grounding or anything else..
