Wicomico County Public Safety
troymail
Silent Key
Drove through Wicomico County last night and wasn't picking anything up on my PSR800. I typically load "control channel" frequencies only so I assumed something had changed.
I loaded the system from the library into a folder set aside for traveling (thanks PSR800!).... and things returned to normal. Clearly, it appears that the system was using one of the other system frequencies as the control channel. Unfortunately, I didn't have logging turned on so I didn't catch which one it was.
Can someone in the area identify the CC freq and submit an update RR?
Wicomico County Public Safety Trunking System, Salisbury, Maryland - Scanner Frequencies
