Hi all-
I have launched a new feed on ProScan, based out of Franklin. The feed is very busy because it covers a wide area thanks to being centrally located with a great antenna installed. I realize this cuts down on the ability to follow incidents closely like on the typical Broadcastify feeds, but I'm sure you'll find the wide scope entertaining and interesting nonetheless.
The feed covers the following with very good reception:
Milwaukee County 800MHz/Conventional
Waukesha County 800MHz/Conventional
Racine County Conventional
Kenosha County Conventional
WISCOM sites (ID search mode) - Greenfield VHF, Greenfield 800, Milwaukee VHF, Delafield, Union Grove, Kenosha, Rubicon
Milwaukee International Airport/Regional ARTCC comms
Wisconsin State Patrol - SE Region 154.665
and more...
The following have spotty to descent coverage, depending on time-of-day and RF conditions:
Washington County P25 (feed has very good reception of the WISCOM Washington Scan talkgroup via the Milwaukee VHF WISCOM site)
Ozaukee County EDACS
Walworth County Conventional
Jefferson County Conventional (feed has very good reception of the WISCOM Jefferson Scan talkgroup via Delafield WISCOM site)
Dodge County Conventional (feed also has Dodge Co Scan talkgroup, via Rubicon WISCOM site)
Lake County, IL Conventional Fire/EMS & Law Enforcement
McHenry County, IL Conventional Fire/EMS
and more...
For those that haven't used ProScan before, it's pretty great for feed monitoring. You can see exactly what's on the display screen of my BCD536HP. It really takes Alpha Tags to the next level.
You can connect to it by downloading the ProScan Free Client at proscan.org.
Once you download the client, connect to:
Server IP Address or Name: Milwaukee/Southeast Wisconsin
Server Port: 5000
20 clients (users) can connect at once with the current setup..
DISCLAIMER: Since it is my belief that encryption should be used for sensitive radio communications, I do not accept responsibility for what you do with the information obtained from listening to this feed. With that said, I will attempt to not broadcast sensitive and/or otherwise legally protected communications.
Let me know what you think, and enjoy!
Josh
and more...
and more...
Server Port: 5000
Josh
