I have one, it kind of works but not very well. On AM BCB and HF its better than a short length of wire stuck in the back of your radio indoors and better on HF than using a VHF/UHF Discone. I haven't played much with mine on VHF/UHF so I don't have any data. I suppose if you lived in a place that was very antenna restrictive and you could only have one small antenna for everything from VLF to UHF, its better than nothing.
The AOR SA7000 consists of a 6ft whip with a transformer that matches a very high impedance to 50 ohms and the mystery loaded VHF/UHF whip. The output of the low frequency transformer and the base of the VHF/UHF whip feed a diplexer with about a 30MHz cross over point to isolate the two antennas while combining them onto one connector.
These antennas are sometimes used by radio and TV stations to receive EAS alerts on broadcast AM, FM and NOAA frequencies to then send out over the radio or TV station. We had one at my last gig and it didn't work very well on FM broadcast band or NOAA so I took it apart and rebuilt it with a specific tuned dipole for 100MHz and 162MHz, which worked much better. The original whip did not resonate anywhere near the needed frequencies for picking up EAS and I have no idea why some companies supply these antennas with their receivers. The 6ft long whip for HF did seem to work ok for picking up AM BCB.
I bought one cheap just to measure the transformer used to match the 6ft whip for HF and its sitting in pieces in my garage at the moment. I should put it all back together and sell it since it will never get used here.
@prcguy Mike I'd be interested in your feedback on this antenna? I'm aware there are some compromises but for a stealthy special application what do you think? I'd be using it primairly on 2M/70Cm, VHF/UHF airbands, marine as well as 11 & 20 meters.
