It's not a scanner it's a ham radio. Everything works fine on my scanners but I wanted to program some repeaters into my ham. But you must pick either "wide" "mid" or "narrow" in one of the sections in the programming software.It would help to know what scanner / receiving radio the OP is using. As has been noted, some of the scanners and other receivers have different meanings for "narrow", "wide", and even "mid" .... which could range from very narrow FM all the way up to FM-broadcast type bandwidth well beyond the "standard" 25 kHz settings for most Amateur Radio analog FM repeaters. So are you programming for receive only, or both receive and transmit use? And with what radio? Your question is a valid one and could have different answers. Knowing the receiver (and transmitter if applicable) will help get more accurate responses here for what you are trying to receive (or transmit into in the case of a repeater).
Yeah I guess I could do that but I haven't had much luck asking local hams for details, they usually just tell me to check the database because "it's all there" but it really isn't. If it was all there I wouldn't need to ask questions on RR lolYou can just ask the owner of the repeater by looking up the call sign and dropping them an email.
It's a tyt uv88 ham radio. I will be programming it to transmit and receive but will only really be listening if I'm being honest.It would help to know what scanner / receiving radio the OP is using. As has been noted, some of the scanners and other receivers have different meanings for "narrow", "wide", and even "mid" .... which could range from very narrow FM all the way up to FM-broadcast type bandwidth well beyond the "standard" 25 kHz settings for most Amateur Radio analog FM repeaters. So are you programming for receive only, or both receive and transmit use? And with what radio? Your question is a valid one and could have different answers. Knowing the receiver (and transmitter if applicable) will help get more accurate responses here for what you are trying to receive (or transmit into in the case of a repeater).
Asking the average ham on the street about the repeaters they use may not get you good info. Find out who the repeater trustee is and ask them.Yeah I guess I could do that but I haven't had much luck asking local hams for details
Use wide. That's probably 5 kHz deviation. If people tell you your audio is too hot then use mid.But you must pick either "wide" "mid" or "narrow" in one of the sections in the programming software.
Audio too hot?Use wide. That's probably 5 kHz deviation. If people tell you your audio is too hot then use mid.
Very few ham repeaters in N America use 2.5 kHz deviaiton narrow FM.
How do I go about that? Some of the repeaters have a blank section under "sponsor" or "owner" when it comes to the repeater etcAsking the average ham on the street about the repeaters they use may not get you good info. Find out who the repeater trustee is and ask them.
Distorted or too loud.Audio too hot?
I'd contact the repeater coordinator for your area and say that you want to get ahold of the trustee of the repeater in question. Ask them if they will give you the trustee's email address or forward your email to the trustee.How do I go about that? Some of the repeaters have a blank section under "sponsor" or "owner" when it comes to the repeater etc
Ohh okay so like your voice comes over the radio abnoxiously loud with a whole bunch of RF noise? And okay thank you mate I appreciate it I will look into this.Distorted or too loud.
I think this is the coordinator for Ontario: Western NY and S. Ontario Repeater Council
I am not referring to a specific repeater. I am wondering if repeaters in general are wide band or narrowband@Clats97 What repeater are you referring to?
It depends. There are probably no narrowband amateur repeaters in Canada.I am not referring to a specific repeater. I am wondering if repeaters in general are wide band or narrowband
Analog Ham repeaters in general are wide band, except of course 900 MHz ham repeaters which are all narrow band. It’s the rare exception that a VHF, or UHF analog ham repeater would be narrow band.I am not referring to a specific repeater. I am wondering if repeaters in general are wide band or narrowband
