Wideband BNC Telescoping whip antenna
iloveswling
Carrollton, TX
I am looking for a Wideband BNC Telescoping whip antenna to listen frequency below 25 MHz (HF) for Yupiteru MVT 7100 multiband handheld receiver. I lost the original antenna. Any recommendations, where can I buy a replacement. Thank you. 73
prcguy
A Maldol AH-W100RX would probably be an upgrade over the stock antenna and it will fold up against the radio. I got a couple of them cheap off Ebay a few years ago.
I would not consider this type antenna broad band, its pulled to a specific length for VHF/UHF and for HF its just a random short whip but that can work ok with a sensitive receiver with high impedance input.
prcguy
questnz
Somwhere in South Pacific
Martin, yes you are correct but I think there is no better substitute for Yupi stock antenna than Watson, most likely best from the bunch of the type, I could be wrong ? It will be hard to get good HF reception on any telescoping thingo
Regards Chris
