Please forgive me if this is something that I should have learned somewhere else or posted somewhere else, but searching on TK-5810 on these forums (or elsewhere on the Internet) have not yielded the answer I seek.
I purchased KPG-95DGN (v. 8.24) to program a pair of TK-5810H(G) K2 Hardware Version 3.0 (400-470 MHz band split) radios hoping I would also be able to use them for wide analog FM (25 kHz) mode in addition to experimenting / learning about P25 mode. The application's help software eludes to the fact that channel bandwidth is specified with the personality as the 'Channel Spacing [kHz]' option. When I key in an amateur or GMRS receive and transmit frequency with Channel Type set to Analog, the 'Channel Spacing [kHz]' parameter only allows the narrowband 12.5 kHz option. Further inspection of the help file indicates that 25.0 kHz can only be selected (unless the channel is configured as 'receive only') if both the transmit and receive frequencies are less than 420.98750 MHz or greater than 470.01250 MHz.
So, I know why, and I cannot complain since these are LMR market radios. My questions are -
1. Since other Kenwood equipment I have used allows to override certain limits, is there something I am missing with these radios that would allow me to work around these limits, or is the hardware really locked down to only transmitting 12.5 kHz on FM beyond the slice between 400 MHz and 420.98750 (probably managed mostly by NTIA and not FCC)?
2. For me to program my Motorola XPR4580 DMR mobile radios (I know, this is not a Motorola forum - bear with me a minute!) to use amateur spectrum with their Trbo RSS software, I hex edit memory while using the application to get frequencies modified to the ISM / amateur band that is within the band split of the radio, but not allowed by the RSS application. My suspicion is that the KPG-95DGN software is enforcing the limits, but I wonder - Does anyone know if there are hardware parameters limiting what bandwidths can operate on what frequencies on this series of equipment?
For what it's worth, I am a noob to this type of Kenwood gear, so I tried older similar software (i.e. KPG-95D and KPG-95DG). Neither of those versions successfully 'read' the configuration of these radios. So, I'm learning all kinds of stuff (probably the hard way and taking some chances), but have not seen or heard if there are known ways of getting wide band to work on these rigs in bands where 25 kHz channels are still widely used / legal.
Thanks in advance for anything you can offer regarding what might be done to make these work as I had hoped, or letting me know that there is no reasonable path to making these capabilities work on this gear.
