wierd ids
VA3JWO
Madoc, Ontario
I own a Uniden bc245 xlt trunktracking scanner. I have it trunking the southeastern fleetnet talkgroups.
Unfortunately, my scanner cant listen to the opp talkgroups, so i lock out those ids. while listening, quite a few different ids came up. they are all digital, but none match the radioreference id list.
does anybody know what they are?
10320, 57872, 2800, are just a few of them. there are many many more that are not listed in radioreference.
does anybody know what these are???
i will list more later as i get more in my lock-out list
DaveH
Ottawa, Ont.
My experience with the BC235 (same vintage, less capable) is that
with weak signals, especially when moving, you can get falsing. Check
strength of the CC.
I found annoying TGs that I had locked out sometimes popped up
as bogus TGs. After a while it was obvious they didn't match known
good ones. It's annoying because it's impossible to lock out all
possible bad ones, and this uses up lockout memories.
TG 2800 is listed and MNR (digital) TG which you won't hear on
you BC245. Some others if they are consistant, could be TGs with
various status bits showing such as for patching, encryption etc.
Dave
