WiFi IP address...
fmurphy
Umbarger,Tx
Just curious if you have more than 1 BCD536HP and want the capability to use wifi on either, is there a way to change the IP address on one so they don't conflict with each other?
kma371
I believe you would need two separate dongles. when configured, they would be each be assigned their own unique ip addresses by your router, so you shouldn't have any issue.
eaf1956
Evansville, IN
so you would have to go through a router and not use the access point setting?
In access point mode each would be 192.168.1.1 but they would each have their own system ID.
For Example:
BCD536HP0001 with 192.168.1.1
BCD536HP0002 with 192.168.1.1
The scanner adds its own number after the BCD536hpXXXX
