WiFi with Starlink
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Has anyone hooked a 536's wifi up to a Starlink router successfully?
I have tried rebooting both the 536/wifi dongle and the Starlink router and just get "Connection Error" on the 536 after selecting the SSID and entering the password.
I'm well versed in connecting devices to wifi so I don't need suggestions like 'are you sure you have the right password/uppercase/lowercase matters' etc., just wondering if there's a particular issue or if anyone has succeeded with this beta-stage device.
Thanks!
ProScan
Software Provider
Ontario, Calif.
Thanks!
I don't have that router. Just a couple of suggestions you can ignore if you want.
You probably already tried connecting other 2.4 GHz WiFi devices to your router.
You probably already used your 536 WiFi on your old router so the Dongle works and the dongle firmware is up to date.
Ubbe
Stockholm, Sweden
Most, if not all, routers have a log function that saves everything that happens. Take a look at it when the 536 tries and connect. Also try another password to see what the logs says then, if the router can differ between the two login attempts.
/Ubbe
