Wildcard (All TG) on Hytera Radios?
itzik
New york
Is it possible to listen to all talk groups on Hytera Radio? pd502 or pd782?
167776415 not working
0xFF1E071F
AFAIK, not possible with a hytera radio. And not possible with any radio. If I am not wrong it is because of the DMR protocol!
YL3IM
KO26BX
There is one exception though: it's possible to turn on (via CPS -> Debeloper mode) OVCM RX for PD6xx and PD7xx so the radio would pick up all group transmissions regardless of Rx List. However the transmission should bear that flag explicitly. For amateur radio systems, one can enable that in MMDVMHost settings on the repeater/hotspot side.
fdnybuff18
NY
How do you turn on the Developer Mode via CPS? I cannot seem to find that.
YL3IM
KO26BX
1. Edit the Settings.ini file (located in the CPS installation folder) by adding these lines:
customview=1
cpsverview=1
They will enable the developer menu switch by itself. But selecting it will produce an error — that's what we need the next steps with developer.usr :)
2. Try opening your codeplug. The CPS will tell where you have to put the developer.usr file to.
3. The path in question partially resides within zip archives, but Windows can handle them natively.
4. Put the developer.usr file to that path.
5. Now you should be able to enable the developer mode.
NB: Due to the forum restrictions the attached file has .txt extension. Rename it to developer.usr after saving.
  • developer.txt
senator715
customview=1
cpsverview=1
Trying to do this on my hp785 units, but doesn't seem to be showing the location in the error
b3053
Brooklyn NY
Is there any way to do this on the PD662? I tried following the steps but the option for developer or customer view never shows up.
