I am used to programming GRE/Whistler radios. How are Wildcards for TG and Private Calls (iCalls) handled in Sentinel? I assume they are only programmed at the system level?
That is correct and recommended so you don't miss the i-calls.I think you can still enter .0 (a dot and then a zero)as the TG and that gives you an i-call wildcard.
Unknown.Sentinel says Invalid TG for both 0 and .0 so I wonder if there is a solution.
Setting an alert for it.
i0 also works but may be considered the same.The i000000 worked as far as Sentinel is concerned. Have ordered radio. I-calls are not used often, so it may be a while before I confirm it works. Setting an alert for it.
