wildland fire feeds
thomasbillman1
Mesa
I have 2 stream up and running for wildland fire season, we still have about a month to go but they are up and running
1) feed : Arizona Department of Forestry and Fire Management Live Audio Feed
this feed has all wildland frequencies that I could find- Prescott NF, Tonto NF, BLM, BIA and State fire using a pro197 with a outdoor vhf/uhs antenna with kmr 400 coax
2) feed : Maricopa County Area Wildland Fire Air Traffic Live Audio Feed
this feed as all air frequencies that I could find for air attack and tankers , using a pro197 scanner with a mag mount vehicle antenna. Both antennas are about 50 ft off the ground . Both streams are using radio feed with broadcastify streaming software . The antenna to the left is my GMR's antenna
Azgunguy
Scottsdale, AZ
Heck yeah. Would you mind listing what freqs you are broadcasting? I work in wildland fire overseeing loading operations for air tankers so I never really get to listen to the good stuff.
thomasbillman1
Mesa
If you go under the feeds click on the icon next to the feed it’ll list all the frequencies that I have program could be a busy summer with all the high grass out there
Azgunguy
Scottsdale, AZ
This seasons going to be crazy. It’s already kicking off. A Fire down near sierra vista has already caused evacuation warnings and that tanker base isn’t open yet.
thomasbillman1
Mesa
if you can not find the frequencies i can post them in here, trying to get more streamers to stream wildland fire, the grass in places is over 3ft high
thomasbillman1
Mesa
ADFFM Repeater Locations:
Repeater 1 - Bill Williams, Towers
Repeater 2 - Black Metal, Greens Peak, Mingus, Mt Lemmon
Repeater 3 - Hayden, Mule Mtn, Signal Peak
Repeater 4 - Cunningham, Elden, Heliograph, Hualapai
Repeater 5 - Bill Williams, White Tanks
Repeater 6 - Mule Mtn, Signal Peak
Repeater 7 - Hualapai, Jacob Lake, Mingus, Mt Lemmon
Repeater 8 - Mt Ord, Nogales Hill
FrequencyInputLicenseTypeToneAlpha TagDescriptionModeTag
151.400159.405RM162.2 PLADFFM - 1Fire - Repeater-1FMNFire Dispatch
151.415159.435RM123.0 PLADFFM - 2Fire - Repeater-2FMNFire Dispatch
151.415159.435RM162.2 PLADFFM - 3Fire - Repeater-3FMNFire Dispatch
151.400159.405RM123.0 PLADFFM - 4Fire - Repeater-4FMNFire Dispatch
154.695153.875RM103.5 PLADFFM - 5 & 6Fire - Repeater-5 & 6FMNFire Dispatch
154.860153.875RM114.8 PLADFFM - 7 & 8Fire - Repeater-7 & 8FMNFire Dispatch
159.330BM110.9 PLADFFM TAC-1TAC 1FMNFire-Tac
159.450BM192.8 PLADFFM TAC-2TAC 2FMNFire-Tac
159.240BM103.5 PLADFFM TAC-3TAC 3FMNFire-Tac
159.285BM151.4 PLADFFM TAC-4TAC 4FMNFire-Tac
159.345BM192.8 PLADFFM TAC-5TAC-5FMNFire-Tac
154.935RM110.9 PLADFFM Flt FlwFlight FollowingFMNAircraft
122.925BMCSQADFFM Pri A2APrimary Air-to-Air (Initial Attack Only)AMAircraft
167.175BMCSQADFFM Pri A2GPrimary Air-to-Ground (Initial Attack Only)
Bureau of Land Management​
Arizona Strip​
168.425169.325RM146.2 PLBLM LE Grand CynGrand CanyonFMNLaw Tac
168.425169.325RM146.2 PLBLM LE Blue RdgBlue RidgeFMNLaw Tac
168.425169.325RM156.7 PLBLM LE Strip MtnMoccassin PkFMNLaw Tac
170.550164.9375RM103.5 PLBLM Jacob LakeJacob LakeFMNFederal
173.825166.3375RM123.0 PLBLM LE Hudson PtHudson PointFMNLaw Tac
173.825168.5375RM123.0 PLBLM Mt HudsonMt HudsonFMNFederal
173.825166.3375RM131.8 PLBLM Black RockBlack RockFMNFederal
173.825166.3375RM136.5 PLBLM LE Scrub PtScrub PointFMNLaw Tac
173.825168.5375RM136.5 PLBLM Schrub PtSchrub PointFMNFederal
173.825166.3375RM146.2 PLBLM Big RidgeBig RidgeFMNFederal
173.825166.3375RM156.7 PLBLM MoccasinMocsassinFMNFederal
173.825166.3375RM167.9 PLBLM LE Mt LoganMt LoganFMNLaw Tac
173.825168.5375RM167.9 PLBLM Mt LoganMt LoganFMNFederal
BLM Common​
163.100BMCSQFed Common 1BLM Common / Fed Common 1FMNFederal
168.275BMCSQBLM TAC 10TAC 10 / Fire TAC 1FMNFire-Tac
168.5375BMCSQBLM TAC 20TAC 20 / Fire TAC 2FMNFire-Tac
BLM Operations​
170.3625172.775RM156.7 PLBLM-BigSprngBig SpringsFMNFederal
169.800172.600CSQBLM-LE-NAT RLaw Enf National RptrFMNLaw Tac
169.700CSQBLM-LE-NAT SLaw Enf National SimplexFMNLaw Tac
163.075BLM-LE/NonLEMt Cunningham (Quartzite Area)FMNLaw Dispatch
169.8125RMCSQBLM-OnSceneScene of ActionFMNFederal
170.5125RM151.4 PLBLM-WF-BWIldifre Repeater (Greenwood, Hayden Peak, Patterson, Perkins)FMNFire Dispatch
169.775RM167.9 PLBLM-WF-AWildfire Repeater (Black Metal, Christmas Tree, Crossman, Smith Peak, and Swansea)FMNFire Dispatch
173.475RM100.0 PLBLM-WF-DWildfire Repeater (Childs)FMNFire Dispatch
173.825RM110.9 PLBLM-WF-EWildfire Repeater (Guthrie, Heliograph, Juniper, Keystone, Mt Lemon, Pinal Peak, West Peak)FMNFire Dispatch
172.525RM100.0 PLBLW-WF-CWildfire Repeater (Harquahala, Horsethief, Oatman, Vekol, White Tanks)
Tonto National Forest​
Law enforcement also uses Maricopa County Sheriff trunked radio system talkgroup Lakes 1005, Maricopa County Sheriff Ch. 8 159.09 MHz or Gila County Sheriff frequencies. Dispatches for San Carlos (callsign- Apache) and Pima (callsign- Pima) Reservations.
1.610KJN298BCSQTNF WX SaguaroWX and Advisory Broadcast - Saguaro LakeAMFederal
170.475164.125KOC286RM203.5 PLTNF-A-DIAMONAdmin Net Diamond Pt (Payson)FMNFederal
170.475164.125KOC286RM210.7 PLTNF-A-HUMBAdmin Net Humboldt (Cave Creek)FMNFederal
170.475164.125KOC286RM218.1 PLTNF-A-AZTECAdmin Net Aztec (Young)FMNFederal
170.475164.125KOC286RM225.7 PLTNF-A-BRONCOAdmin Net Bronco Butte (Apache Lake)FMNFederal
170.475164.125KOC286RM233.6 PLTNF-A-SIG PKAdmin Net Signal Pk (Globe)FMNFederal
170.475164.125KOC286RM241.8 PLTNF-A-MT ORDAdmin Net Mt Ord (Nof Phx)FMNFederal
170.500164.1875KOC286RM203.5 PLTNF-2-DIAMONFire Net 2 Diamond Pt (Payson)FMNFire Dispatch
170.500164.1875KOC286RM210.7 PLTNF-2-HUMBFire Net 2 Humboldt (Cave Creek)FMNFire Dispatch
170.500164.1875KOC286RM218.1 PLTNF-2-AZTECFire Net 2 Aztec (Young)FMNFire Dispatch
170.500164.1875KOC286RM225.7 PLTNF-2-BRONCOFire Net 2 Bronco Butte (Apache Lake)FMNFire Dispatch
170.500164.1875KOC286RM233.6 PLTNF-2-SIG PKFire Net 2 Signal Pk (Globe)FMNFire Dispatch
170.500164.1875KOC286RM241.8 PLTNF-2-MT ORDFire Net 2 Mt Ord (N of Phx)FMNFire Dispatch
171.500164.825KOC286RM203.5 PLTNF-1-DIAMONFire Net 1 Diamond Pt (Payson)FMNFire Dispatch
171.500164.825KOC286RM210.7 PLTNF-1-HUMBFire Net 1 Humboldt (Cave Creek)FMNFire Dispatch
171.500164.825KOC286RM218.1 PLTNF-1-AZTECFire Net 1 Aztec (Young)FMNFire Dispatch
171.500164.825KOC286RM225.7 PLTNF-1-BRONCOFire Net 1 Bronco Butte (Apache Lake)FMNFire Dispatch
171.500164.825KOC286RM233.6 PLTNF-1-SIG PKFire Net 1 Signal Pk (Globe)FMNFire Dispatch
171.500164.825KOC286RM241.8 PLTNF-1-MT ORD
n0nhj
In way too deep...
Glenwood Springs, CO
On your feed description, you might want to note the receiver location. I doubt you are hearing all the traffic statewide, and someone might get misled by a frequency on your list that is out of range.
Regards
Chuck
