I am new to SDRs, still learning quite a bit about radio.
I have been monitoring local public safety channels on the 800Mhz frequency range, a P25 system.
I'm currently using an rtl-sdr V3 and sdrtrunk. The setup is working well but I have a couple of changes I would like to make.
I live outside of town, 9 miles line of sight from the transmitting tower. I have an antenna mast that was on this home when we purchased and can get the antenna above surrounding trees for a clear shot into town.
I bought a yagi antenna from ebay which is a browning BR-6386 with a type-n fitting and 9-db gain.
I originally had the antenna at the top of my mast, 40 feet above ground so I purchased 50 feet of DX engineering 400max coax. The cable seems great and I don't really have any issues with it.
But that's where my first question comes in:
In sdrtrunk, using the above setup, I consistently get a channel power of about -18db. It seems to stay locked on to the control channel and rarely seems to drop traffic. However, I ended up moving the yagi lower on the antenna, and could probably get away with a coax length of much less, maybe 20 feet or thereabouts. How much of a difference would/could a 30' reduction in coax length be noticed?
Lastly, is there a better type of coax for my purpose (decoding P25 channel using an rtl-sdr V3) than the DX engineering 400max?
Thanks for any help.
