Will a Whistler 1040 receive an LTR or a DMR Motorola Connect Plus System?
tvengr
Well Known Member
Baltimore County, MD
The 1040 cannot decode DMR. It can receive a LTR standard system. Which LTR system are you interested in?
hiegtx
Dallas, TX
How do i set it up for LTR. I would appreciate the help.
John
If programming manually, follow the steps in the Easier to Read manual that includes your scanner:
I don't see an LTR system listed in the database for your county (Marshall, WV). If you are trying to program a system that is in the database (but not in your home county), be sure to enter the correct LCNs from the database. If the system is not in the database, but you know that it is LTR & in use, then activate the AutoMove option when entering the system and it's frequencies (that's mentioned in the Easier to Read manual section I linked).
