Will CDM1250 transmit two tone encode
matt131
Hello,
I have been searching for the answer but can't seem to find it. I may not be searching correctly, but can someone please answer the following:
Will the CDM1250 transmit two tone pages? Can you do this with regular radio programming?
Matt
LATA 722
Mine will, however there seems to be some real differences between exact models of CDM's that I've never been able to understand. Seems like some do, some don't. Of all the CDM's I have, including 1550's and 1250's, they all do two tone decode. Standard programming software allows set up.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Every CDM1250 that I have worked on will transmit QC-II just fine, regardless of model number or configuration. Same for decode. I've not heard of a 1250 that won't.
It's the 1550's that have some real variations in them. Some do and some don't handle QC-II.
For the OP, one thing you can do is examine the codeplug. If you can set up QC-II encode, then the radio should do it. There are sample codeplugs for every possible model of the CDM's in the Samples folder. It gets installed when you installed the CPS.
evfd1625
Indiana
The 1550 ls+ will handle anything, the regular ls and the regular 1550 I couldn't tell you.
Sent from my SM-N900V using Tapatalk
