Will Co P25 new system
RoninJoliet
ILL
This system is up and running, its listed here on the rr.com database , the 855.0375cc and 855.6625cc are being used..All the proper freqys are listed in a post on the RS forum....Joliet Junior College has moved from the WC-River System to this new system...My Uniden scanners copy this system fine but my RS197 and RS106 digital scanners do not pass any audio at all but the signal is (5) bars, if anyone else installs this system in GRE/RS digital scanner and can hear the audio please post it....The WC-River system has no users at this time that I hear as Lockport and Cresthill towns are now on Starcom.....
RoninJoliet
ILL
OK, I just got my answer to the RS/GRE problem from a contributor on Radio Shack forum, if you monitor this new system with a GRE/RS digital scanner it t must be set to "P25 Manual" not P25 Auto....
cubn
Marion/Johnson County, IN
A database submission from mid-October reported these frequencies in using via Pro96com.
Code:
FileVersion:8
-TowerInfo
#This section is here for information only.  With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID             : 011
System Name           :
WACN                  : 000C5
Tower Number (Decimal): 1-1
Tower Number (Hex)    : T0101
Tower Description     :
Control Capabilities  : Data,Voice,Registration
Flavor                : Phase 2
Call Sign(s)          :
Timestamp             : Thu Oct 12 01:44:14 2017
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0593","c",854.71250,"00-0593",809.71250,0,0
"00-0645","ca",855.03750,"00-0645",855.03750,1,0
This is where the confusion with the control channel frequencies were introduced. I updated the frequencies in the RR database to what you reported this week they are using.
RoninJoliet
ILL
Thank You i will check it out , if there are errors will let you know....
RoninJoliet
ILL
The two there i have seen as CC's, the license shows the following to add to them, 856.0875, 856.3875, 857.3875, 859.0125 and 859.4125.....Also, as mentioned in above posting i had to use on my GRE/RS digital scanners ONLY a setting of "P25 MANUAL...The Unidens are fine....Will County may be "ENC" , it remains to be seen.....
RoninJoliet
ILL
Will Co using there new E.F.Johnson P25 system today with simulcasting of "West Patrol on TG20003, and "Animal Ctrl on TG10410....So far in the open.....
nick223
Ottawa Illinois
Will County Sheriff officially is switched to the new system as of 15 min ago.
This was sent to me an hour ago. I’m assuming their using this new system.
RoninJoliet
ILL
I also heard the same message as Dec 11 was the cut over date however, I still hear them on the EDACS...
cubn
Are the sheriff's dispatch talkgroups Phase 2 or Phase 1? I had a submission that 200003 is Phase 2 but on CARMA they're saying the WEST and EAST talkgroups are Phase 1.
Wb9woz
Phase 2 or not
I'm seeing TG 20001 and 20003 both as Phase 2
both in the clear
Bruce
wb9woz
RoninJoliet
ILL
I think what was written is the "System" is capable of PhaseII but things are now dispatched in PhaseI because my 996P2 and 325P2 both show P25, like up north when I was in Elgin I saw some NWCD TG's showing "P0" and "P1" which is PhaseII , the scanners mentioned do NOT show that on Will Co....The Starcom system is PhaseII capable but none of the dispatching around here is that phase cause I was told most towns still have not upgraded there radios.....Too costly!!
151plower
Any idea when we will see the new Will County frequencies updated into the database for programming the Uniden Home Patrol? Also, it seems like something has changed with Crest Hill PDs frequency because I am no longer receiving anything from them. I got some great help here manually programming their changes about a year ago, but I've not heard anything from them in some time. Thanks!
MikeyC
Utica, IL
Crest Hill is dispatched by WESCOM and should be on StarCom TG 33911 (with tactical and other talkgroups between 33912 and 33915). Crest Hill was on the Will County system for a bit, correct?
I only pass through the area every now and then so the locals may be more in tune ;)
RoninJoliet
ILL
Yes , Cresthill and LKPT were on the river system but that's been shut down and there on Starcom as the previous post shows TG33911.....
Wb9woz
will county talkgroups
I've let Pro96com run for 24 hrs. Other then talkgroups identified already, here are some new ones
571
10133 ENC (different from 10113)
10301
10401
10701
10704
15503
20003
20004
20005
20006
Using a Whister WS1095 from Woodridge IL
Bruce
wb9woz
AC9BX
Lockport, IL
I saw them in Phase 2. Database was changed to phase 1. I haven't checked yet. The system is populating quickly. Corrections, highway, Lincolnway police, ... more to come. The River system is off the air.
AC9BX
Lockport, IL
Unitrunker collected data, about 3 hours
Channel lcn=645 855037500 control
Channel lcn=745 855662500
Channel lcn=813 856087500
Channel lcn=861 856387500
Channel lcn=1021 857387500
Channel lcn=1281 859012500
Channel lcn=1345 859412500
groups and number of hits
131 34
151 45
341 1
351 1
371 62
10101 1
10102 1
10103 1
10105 96
10106 6
10131 1
10132 3
10133 1
10134 1
10135 1
10136 1
10200 16
10201 232
10202 110
10203 1
10204 1
10205 1
10301 1
10302 1
10303 1
10401 27
10501 12
10502 1
10601 1
10701 2
10702 1
10703 1
10704 22
15001 91
15002 19
15003 1
15004 1
15005 1
15012 7
15014 7
15015 12
15021 1
15022 1
15041 1
15063 1
15095 1
15099 3
15501 1
15502 1
15503 1
20001 337
20002 1
20003 278
20004 8
20005 254
20006 1
20007 1
20008 1
KC9LEA
Tinley Park, IL
Updates
All traffic is currently Phase I, since a solid 75-80% of users acquired used equipment. I have been able to recieve all the talkgroups listed in the reference on Phase 1 capable equipment. Today at about 1315 Hours the Patch from the old East Patrol TG was shut off. I can only imagine West will be soon to follow.
RoninJoliet
ILL
YUP, not hearing anyone on the EDACS now , all on P25 system....Romeoville PD just moved over to WCo system also and kind of weird using same TG20003 as West Patrol ??....Sounds like FPR-PD is TG10704 don't know who TG371 is...Braidwood is moving to WCoP25 system but there fire staying on Starcom, this is a real puzzle!!!
