Dewey
- Joined
- Dec 19, 2002
- Messages
- 1,067
- Reaction score
- 61
I have been running multiple scanners through "common" TV splitters for YEARS (I bring the signal into the house with quality quad-shield 75 ohm coax). Since I'm in the DC Metro area, I am not at a loss for strong signals. I am thinking about upgrading my antenna system from the Sputnik (RS 20-176) to a Diamond Discone D130J. If I do further chase this thought (I'm in the homework stage right now), I'll probably upgrade the entire antenna system. On the inside, I'm considering going from the regular TV splitter to a passive or active Stridesberg. Here's where my question comes in. While I have several scanners from upgrading over the years, I normally only run two as base units... the others are portables anyway. While using a passive two port Stridesberg shouldn't hurt my signal too bad (actually, it should still improve when compared to the TV splitter), I have not totally ruled out an active Strideberg. BUT, if I shell out the $$$ for an active Strideberg, I'm thinking for just a little more, I can have four ports instead of two. Will two unterminated ports (for those "normal" times when I'm only running two scanners) hurt me in the signal department? I still remember an old argument from the 70's about using terminators on unused F-connector TV jacks to help with TV reception.
Thanks,
Dewey
Thanks,
Dewey
