mlevin
I just just saw this TRS, and wondered if the Pro 96 will work on it.
http://radioreference.com/modules.php?name=TRSDB&sid=3640
baybum said:I'd like to give this a try but there's one problem...I can't get the exact frequency to program correctly.
XXX.2125 comes up as XXX.21500
How can I get the PRO-96 to accept the correct freqs?
Mike
kg4icg said:well let's see, that was entered for massachusset's so how that ened up in dc i don't know. that system isn't around here.
R Collins
kg4icg said:Thing is that type of trunk system isn't around here though, and i go thru DC everyday. Try a little experiment, take 10.7mhz which is basically the if freq of every scanner made multiply it by 2 and then add it to the frequencies you think it's on and see if it doesn't come up to the new trunk system that is around dc that is totally encrypted. What you guys might be receiving because all of the rf in this area is the image of the new trunk system 21.4 mhz down from where it is. Just a place to start.
