Wouldn't this be negated in all modes by setting P25 waiting time to zero?Actually, if you set the channel to Analog for analog channels, the channel will "open" sooner. When set to "ALL" the scanner suppresses audio for about 400 mS while it tries to determine if the signal is P25. If P25 is not detected within this time, it then opens the audio. This prevents you from hearing the data noise during the detection process.
OK, I was looking at the freescan screen, Guess it is their regardless of system type. Thanks again UPMan.Tryton: There is no such setting for P25 systems.
