BobW55
I did a search on the DPD Air Omni UHF/VHF Base Antenna, but did not walk away with a definitive answer to: will it out perform a discone on the aviation bands?
I am talking both civilian and military air bands.
I just upgraded my coax to my discone from RG213 to LMR 400, Approx. 100' run. Yes I did see an improvement of about 1 more bar (SDS200) and can just pull in two more of the weather stations. I can almost make out some of the ground stuff from Selfridge ANG. They are 40 miles out at 580 feet elevation I am at 840' elevation.
My discone is 35' up on a tower.
If I replace the discone with the DPD antenna,( Same height & Coax run) will my Air band receive be noticeably better, or the about the same?
