WIll this scanner work for me?
Sirsmegalot
Radio Shack Pro-107 iscan trunking scanner
Does anyone know if this will work for police dispatch in Little Rock Arkansas?
Ive done some research just would like confirmed by experts before going for it
http://images.craigslist.org/00707_jhBb3qKqtEi_600x450.jpg
thanks
info:
http://wiki.radioreference.com/index.php/Pro-107
https://www.radioreference.com/apps/db/?ctid=167
some info from another thread:
Little Rock is in the process of converting to AWIN, not finalized yet. To monitor the Analog system currently you will need a scanner capable of doing the rebanded setup. To monitor in the coming months, yeah you will need an scanner capable of doing P25. Anything in the PRO-96/2096 generation, up through the BCD396/996XT generation all the way to PSR-500 PSR-800, PRO-106, PRO-18, Home Patrol 1, will work fine
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If this system is indeed going to AWIN I wouldn't bother with the 107, which only trunks analog trunking systems.
All digital trunktrackers can also handle analog trunks as well, so you wouldn't be missing out on anything. However I'd become more famiiar with your area, scanning wise, before making a purchase. Use our forums; check out the database for your area and surrounding communities.
Mike
