Will Uniden be able to help me?
I have a pro505xl cb and it looks like the back antenna connection is loose. It really screws up the reception and the number of watts displayed on screen. In order to get reception, I have to jiggle it upwards to display watts.
In the owners manual it clearly says it the warranty that I they will only repair manufacturing defects. Does this mean I have a problem and can't send It two them under my warranty? Or will I have to pay some flat rate repair price?
Very confusing wording in the manual
KD8DVR
Columbus, Ohio
I'd call them. sounds like a manufacturing defect to me. It isn't displaying watts, unless the connection to the antenna is made.
So Far Away....
Open the unit up,Take a look at the connector,see if its a bad solder.
Chances are you can do the repair yourself.the ant connector is a very
simple connection.the ground go's to the chassis,and the center pin will
attach to the board inside..
Woo hoo! Called Uniden and told them about the problem and they said I could ship It off for repair no problem!
