Wilson 800 Yagi question
h8tdigitalradio
Six Feet Under
Hello,
I cannot say you will hear the system you are trying to monitor better with the Wilson Yagi. However, Wilson makes a very good Yagi, which I use regularly to monitor 800 MHz systems with good distance from the QTH. I also use Wilson's NMO mount cellular antenna for mobile use. I would use their products, no questions asked. :)
HTHs
73
Dave AKA The Tripzter
iMONITOR
Silent Key
S.E. Michigan
will this yagi work on my 996 for 800 P25 system?
Wilson Yagi Cellular Antenna 301111 - Free Shipping.
I'm looking for something to get better signal on my local ISP which is 800 mhz P25 the scantenna just don't cut it for this system.
I don't now what antenna you're currently using, but if you're getting any signal now, this should definitely improve it. Make sure it's pointed toward your signal source, and mount it at a reasonable height. Use good quality low loss coax and you should be all set. If it's for receive only, then a good quality RG6 will do.
Sinister
New Hampshire
I just bought one from ebay paid $32.00 shipped. I have not had a chance to put it up yet but just connecting it to the scanner in my basement I get 2 to 3 bars so I imagine it will only be better mounted up high.
