win 500
RDCat
N.W.
on the last page of win 500 importing from radio ref
the line box says, TSYS OBJECT says -1? is that what setting it should be?>>
and the same in the starting TGRP OBJECT ID box is -1
should i leave those numbers the same?
what are they for?
thanks ron
DonS
Franktown, CO
Those are for assigning "Object ID" values to the created TSYS and TGRP objects. If you leave them at the default of "-1", Win500 will choose the object IDs.
The TSYS Object ID field is also used if you're importing only talkgroups into an existing TSYS. Setting that field to the Object ID of an existing TSYS, without selecting any sites or frequencies, will add the selected TGRPs to that TSYS.
RDCat
N.W.
ok i'm confused i'll email u about your last sentence!!!!!!1tsys object id
