Win 96, Pro-206 and Virginia STARS
BlueMoon2
Midlothian, VA
Hello everyone,
I was referred to this forum to see if someone on here can resolve my issue. I am trying to program several Virginia STARS repeaters into a RadioShack Pro-2096 using a WIN 96 for a friend of mine. The first frequency that I am trying to program in is "161.8625". However, when I input that in, it automatically goes to 161.8650 no matter how many times I have put it in. I have the latest version of Win 96. I have tried to let it scan the system as it, but it will not work. All of my talkgroups have already been entered.
W4UVV on the Virginia forum suggested his single table settings and I tried that, and it didn't work for the same program. What gives?
My BCD996XT works fine with similar settings and my GRE PSR-500 works fine with the same settings. Not the RadioShack Pro-2096 though. Any thoughts?
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
WIN96 Settings/Weather tab
Hi Andrew-
If you check the box marked "Extended Frequencies" on the WIN96 Settings/Weather tab, it should allow you to enter the frequencies without rounding them. You can find that box under the batter Hi / Lo settings at the bottom of that particular page.
Hope that helps you,
BlueMoon2
Midlothian, VA
Win96 Suggestion
The win96 suggestion for checking the "extended frequencies" did not work. I clicked on the box and tried to enter the 161.8625 frequency again, it didn't work. Any other suggestions? Somebody in another forum suggested a 2.50 khz step size, that didn't work. I'm out of ideas.
BlueMoon2
Midlothian, VA
Pro-2096 and STARS
See attachments for what I have done with the Win96 for the Pro-2096. Do I have the settings correct for the STARS system? I told this guy that I would have his scanner back to him by this Friday, and I need to figure this out. Thank you for all your help.
BlueMoon2
Midlothian, VA
Ok I think I did try this and it didn't work at the time. Are there confirmed results with this? If so what are they? For whatever reason I'm having a heck of a time getting this to work for frequencies for this scanner. Thank you
