win 97 programming
stevolene
chattanooga metro
for some reason this is the most complicated software Ive ever seen, it cannot read the pro 97 nor find a com port, please help..................should I use the highly touted scancat software instead?
KE5BCP
Analog Man
Lewisville, Texas
No way.... you have the "best" software using Win97.
Tell us exactly what you have seen on the screen after installing the cable driver and Win97.
jb872033
Cromwell CT
had the same problem..once it is figured out you will not be dissapointed...worst comes to worst just start with com 1 and work your way down...make sure however your driver for the cable is installed properly or it wont be recognized...idk if it is the same com port for every compter or it just happened to be the same with both of my computers but com-4 is where my usb is located on both computer..try there and work your way down the list till you find it...good luck
JB
n2mdk
Ames, IA
Find the COM port that the computer assigned to the USB cable in device manage. Enter it into the software and you should be good to go.
stevolene
chattanooga metro
10 4 will try that..........actually Ive reloaded windows since I bought that cable, I couldnt remember if a disc came with it or not
