Win500 and recording
woebbers
Valley Forge Pa
Hi Everyone,
This is most likely a novice quaestion but I feel there is no better place to ask it then here. I have a Pro-197 and the new version of Win500. I have the recording end figured out but what i want to know is, Is there a way to listen to the scanner while you record? Or is this a computer issue?
Thanks in advance
Sal
RadioTech19
Pomeroy, OH
You should be able to listen to the scanner audio through the computer speakers if the scanner is plugged into a line in or a microphone jack. Make sure your speaker volume is up and if everything is hooked up right...you should be able to listen and record at the same time. Good Luck!!!
