I have and use all of Starrsoft's software. I have at least two USB cables including 20-047. All the programs, except WIN500, work with no issues with either cable.
First a note that this was all installed and working for years on my XP Pro system. I had to rebuild the hard drive. I have copies of everything. This is the only issue I've run into after the rebuild.
I've tried various versions of WIN500 (2.05,2.06,2.07,2.08) and they all do it. No problems with WIN92,WIN93,WIN95,WIN97.
When you try to either upload to the scanner or download from the scanner, the following exception message appears.
I'll note that I've tried various versions of the FTDI driver including 2.08 & 2.12.
BTW, I don't need comments about using a later O/S. Thanks.
