win500 objectID duplicated error
pathalogical
Toronto, Canada
I've been getting "One or more objectIDs are duplicated (or are not valid) and must be fixed" when uploading to Pro 106. It asks to fix them and I click YES. It doesn't say which object IDs and I still get the same message. How do I find these IDs so I can look at them ?
I think "not valid" means they are not assigned to a scan list or tgrpsys??.. not sure cause I do have t.
hat radio yet tho
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
In each TSYS, right click on ID header of TGRP section. Select "Sort on Column - Ascending". Scroll the listings for duplicity and/or scanlist assignment.
Do the same for conventional objects.
Edit: The above can be accomplished using the same ID header in "all Objects" tab.
pathalogical
Toronto, Canada
hmmm...I think I might know what happened. 1800 objects per scanlist, right ? Can an object be numbered 1801, 1802 etc ? The column does show a 5 digit ID possibility.
When I started programing manually, the object numbers seemed random. Now with win500, the ID column in ascending order shows 00869 followed by 00888. I currently have 898 objects in this scanlist.
fmon
Eclipse, Virginia
It's not scanlist per say but Objects., and the number is actually 1852. 00000 - 01851. Keep in mind, each TSYS will use 10 - 20 Objects.
Regarding Scanlist, each non-TSYS object should associate to a scanlist and of course, all Objects of a TSYS should be in the lower listing when that TSYS is highlighted, though they can use one or all scanlist.
ecanderson
Colorado
Just had the same problem (current level software, 01.99) and the source WAS numbering some objects as 02000, 02001, 02002, etc. Once I reduced those to 01800, 01801, 01802, the complaints during transfer ceased.
