Win500 pro-197 p25 trunking settings
nozzle75
Easley, SC USA
I have a Pro-197 scanner set to scan a local P25 800 Mhz trunking system programmed with latest version of WIN500. I have great signal, but the audio is garbled. The talkgroups in questions are clear and not encrypted. I have swapped antennas, used coax, used direct connection with different antenna, and more.
Should I consider changing the settings for the P25 settings in an effort to help? If so, what do I change?
Thanks!
City of Maricopa, Arizona
I have the same problem with my Pro-106 for Mesa Arizona Police. The Maricopa Sheriff comes through pretty good but they are not on a P25 system like Mesa is. I am also looking for an answer so I hope you get a reply from some of these experts on here.
k7aab
Horace
I forced the system to use Narrow FM in the system menu, cleared things up for me. It is set at wide FM as a default. I don't know why they'd do that.
