Win500 Question...
PriorMike
Arnprior, Ontario, Canada
I have a trunked system in my Pro-197 that I'd like to add another site to.
Can I do it the same way that I'd add additional talkgroups? ie Import them in and enter the system object ID in the import options?
Thanks.
u2brent
OAMPT
KRWDPAXKRS1
Adding frequencies to an existing TSYS
Add the new site's frequencies to the existing TSYS Object's SYSTEM FREQUENCIES.
(Note: You can only have 32 total frequencies per system.)
They are not scanned as separate sites as the more modern scanners do; but rather it will scan all the programmed frequencies in the list (Regardless of site info) This is where hobbyist's began the habit of only putting in the Red/Blue CC frequencies because of the 32 ch. limit.
If the existing system is already using all 32 for other sites then you have to create a new TSYS or delete some frequencies from more distant sites or non CC channels that are not needed.
I think that's correct.....:lol:
u2brent
OAMPT
KRWDPAXKRS1
Oh, BTW,
Those directions assumed the system was P25/Motorola.
LTR & EDACS systems would need to have a new TSYS created and then add the frequencies in the proper LCN positions (1-14)
