WIN500 scan list and skywarn
mrnavy2
Ocean Twp, Monmouth County, Central New Jersey
Hello all I am new to Win500 so plz be patience with me. I have 2 questions:
1. How.can I combine 2 scan lists in 1. Whst I mean I want to take scan list 1 n 2 and just put them noth on scanlist 1.
2. And how do I add Skywarn onto and set it on my pro 197 using Win500.
Thanks for your help.
RDGDigital
MD - Eastern Shore
To answer your first question...
  • Make sure Win500 and your scanner are communicating.
  • Load Win500 with the your current configuration. Either from a backup file are by uploading directly from the scanner (from the menu select Scanner>>Download from Scanner). If you download directly from the scanner you may want to save this configuration to a file just in case, so you have a backup of your current configuration.
  • In Win500 select the All Objects tab.
  • In the Scan Lists column change everything with a 2 to a 1. You can select multiple items at a time and change them all at once.
  • And finally save this configuration to a file and then upload it to the scanner by selecting Scanner>>Upload to Scanner from the menu.
I can't answer your second question since I never use Skywarn.
I hope this helps.
