SKINNY1
Win500 stopped working after latest Windows 11 upgrade. Anyone else have this issue in the last day or two?
If he did the latest upgrade, he should have the updatesUpdate windows
You click on the win500 icon and it says loading and then dispears not opening the program.Define "stopped working"
Tried botn, still a no go. When clicking on the win500 app it just popps up saying - loading for about 5 seconds then disappears.Try disabling virus software and firewall
This is a long shot, and it has not cropped up recently (unless I missed the comments), but several years ago, and several versions of Windows ago, DEP (Data Execution Protection was causing problems. I have not seen references to this recently, but there are a number of older threads where this cropped up.Tried botn, still a no go. When clicking on the win500 app it just popps up saying - loading for about 5 seconds then disappears.
Thank you, I will give that a try.This is a long shot, and it has not cropped up recently (unless I missed the comments), but several years ago, and several versions of Windows ago, DEP (Data Execution Protection was causing problems. I have not seen references to this recently, but there are a number of older threads where this cropped up.
WIN500 wont boot up
My Win500 wont start, everytime I try I get the message: WIN500 Scanner Utility has stopped working. I am up to date on the software, I am using Vista 64 bit. My WIN96 program works fine. Thanks, Jimforums.radioreference.comWIN500 wont boot up
My Win500 wont start, everytime I try I get the message: WIN500 Scanner Utility has stopped working. I am up to date on the software, I am using Vista 64 bit. My WIN96 program works fine. Thanks, Jimforums.radioreference.comWin 500 has stopped working
fmon, Didn't we have problems a while back with Win500 with the Firewall or Virus Protection where we had to give it permission of some kind? I can't remember why we had to do it.forums.radioreference.comWin97 no longer works w/Vista
did you install the drivers for the cable (Vista version?), unplug the cable & install,reboot 1st & then make sure win96 comport matches what is showing in Vistaforums.radioreference.com
Do a forum search & you'll see several threads (most 10 years, or longer, ago) mentioning this.
Thank you so very much Hiegtx! Win500 now works, culprit was Data Execution Prevention.This is a long shot, and it has not cropped up recently (unless I missed the comments), but several years ago, and several versions of Windows ago, DEP (Data Execution Protection was causing problems. I have not seen references to this recently, but there are a number of older threads where this cropped up.
WIN500 wont boot up
You’re welcome.Thank you so very much Hiegtx! Win500 now works, culprit was Data Execution Prevention.
You can also use Butel ARC500. Both ARC500 and PSREdit500 have a free trial period to determine which one you like better. ARC500 Basic is all you need to program your scanner. The Pro version provides additional logging functions.Nothing has worked yet, as far as getting win500 working. I installed and have PSR-500/600 working with no issues. But I like win500 better. Weird!
