N8OAY
I downloaded and installed Win500 on my Toshiba L505D-S5983 laptop yesterday. After a reboot or resume from suspend, it will not run giving me a message that the system clock has been changed, possibly in an attempt to disable security features of the program, and telling me to reset to clock to original settings. To be sure that this was not an issue of the program being corrupted, I deleted everything and downloaded a new copy and installed it. The new copy would not run, giving me the same error. To be sure it was not something else on my laptop causing the problem, I ran System Restore resetting to before Win500 was installed, then deleted the installed copy, downloaded and installed Win500 for the 3rd time. It ran fine, until I shut the laptop down last night. Today I have the same problem. Win96 which is a registered copy runs fine on the laptop. The clock has been changed on the laptop - I moved to Alabama from Ohio a couple months ago and changed to the Central Time Zone. That change was made long before Win500 was installed. What is causing this, and what do I need to do to fix it. I am not going to register the program if I can't get it to run.
