JoeyC
Senior Member
This is minor asthetics but should be changed in an upcoming version.
When you do a RR web import for Trunked Systems and you are brought to the Web Import Settings screen there is a section for Talk Group Alpha Tag Format.
The 2nd choice should be changed to say "Alpha Tag" to match the RR database. Currently it shows "Display" which I think was abandoned in RR quite a while ago. The conventional import side shows "Alpha Tag" correctly.
Also option 3 in Alpha Tag Format Conventional allows a custom text to precede the Alpha Tag, Can this option be included in Trunked systems as well?
