Win500-What are these numbers im getting?
So Far Away....
i cant seem to figure our what teh five digit numbers are,second to last column,00631.00673..
radio is a pro106
..............................................................................................................................here
03:23:33, 0207, TGRP E 24*26 304, TSYS=0165, PHL-PD x2 --DG,--866.787500---------00631
03:26:03, 0207, TGRP E 24*26 304, TSYS=0165, PHL-PD x2 --DG,--867.100000 ARID:---------7632
03:26:20, 0207, TGRP E 24*26 304, TSYS=0165, PHL-PD x2 --DG,--867.837500---------00673
03:27:02, 0207, TGRP E 24*26 304, TSYS=0165, PHL-PD x2 --DG,--867.112500 ARID:---------62456
03:27:11, 0207, TGRP E 24*26 304, TSYS=0165, PHL-PD x2 --DG,--866.787500 ARID:----------7632
trap5858
Doylestown PA & Milton DE
The radio is logging the hits on the various talk groups. I believe you can turn off this feature.
Where in Philly are you? I'm a bit north of the city but lived there for many years!
So Far Away....
i know its logging the data,im sure
its not the TGs.
the TGID for that dist is 304,the
radio id's are tagged,,
the radio id's are shown on the bottom right
of the display-LCD on the 106,,
this set of numbers is popping up in the
center,bottom line of the radios LCD..just above
the F2 button..
its drivin me nutts.
davidmc36
South East Ontario
the F2 button..
It is the LCN of the system that the current conversation is transmitting on. If the scanner misses the RID it displays the LCN where you are seeing it.
So Far Away....
curious,
wouldnt and LCN be used with a EDACS system,,
not on a motorola Type II SmartZone like here in philly?
davidmc36
South East Ontario
curious,
Motorola systems also have LCN's. They are just handled differently and you don't need to put them in order in your scanner for the Moto systems.
DonS
Franktown, CO
That is exactly correct. The Win500 log would look similar to this:
Code:
08:20:14, 0106, TGRP  , Police Records  ,      112, TSYS=0100, Santa Clara City, AN,  866.462500 RadioID:    2771
08:20:26, 0106, TGRP  , Police Records  ,      112, TSYS=0100, Santa Clara City, AN,  868.887500 RadioID:    2842
08:22:34, 0103, TGRP  , Police Dispatch ,       16, TSYS=0100, Santa Clara City, AN,  866.837500 RadioID:    4815
08:22:41, 0103, TGRP  , Police Dispatch ,       16, TSYS=0100, Santa Clara City, AN,  866.837500       00633
08:22:47, 0103, TGRP  , Police Dispatch ,       16, TSYS=0100, Santa Clara City, AN,  866.462500 RadioID:     201
08:22:58, 0103, TGRP  , Police Dispatch ,       16, TSYS=0100, Santa Clara City, AN,  868.887500 RadioID:    4785
08:23:08, 0103, TGRP  , Police Dispatch ,       16, TSYS=0100, Santa Clara City, AN,  867.862500       00674
08:23:22, 0103, TGRP  , Police Dispatch ,       16, TSYS=0100, Santa Clara City, AN,  867.337500 RadioID:     201
08:23:32, 0103, TGRP  , Police Dispatch ,       16, TSYS=0100, Santa Clara City, AN,  867.075000 RadioID:    4815
08:23:51, 0103, TGRP  , Police Dispatch ,       16, TSYS=0100, Santa Clara City, AN,  866.462500 RadioID:     201
The lines that end with "RadioID: xxx" are where the scanner was able to obtain the RadioID from the control channel. The lines that end with "nnnnn" are where the scanner did NOT get the RadioID, so it was showing the "channel number" on the 4th line of the LCD.
The "channel number" is shown as:
* MOT / P25: 5-digit decimal number with leading zeroes
* EDACS: 2-digit decimal number prefixed by "LCN"
* LTR: 2-digit decimal number prefixed by "R"
To get such results, you must have the PGM GLOB menu's "Trunking Ch#" set to "On" and "Show RadioID" set to "Yes". The RadioID, if enabled and available, will override display of the channel number.
