WIN500client mobile
Astrak
Mesa, AZ
Just flashed to a new ROM WinMo 6.5 TF3d 2.5 sense UI on my touch diamond, I'm getting an error when I try to run WIN500client
"System.Windows.Forms,
Version=3.5.0.0, culture=neutral,
PublicKey Token=969DB8053D3322AC or
one of its dependencies, was not found"
My guess is that's because TF3d 2.5 uses .net3.7, but I'm not sure does anyone know?
Astrak
Mesa, AZ
Anybody with a Touch PRO2 or any newer HTC WinMo device tried WIN500client and had any luck? It works great on .net3.5 framework and older versions of WinMo6.5. If you don't have WIN500 running PM me and I can give you an IP and port to connect to so it can be tested.
DonS
Franktown, CO
For testing, you can also connect to:
IP Address: 64.2.60.23
Port:26755
Unfortunately, I don't have a Windows Mobile device with .NET 3.7 installed, so I cannot test this particular problem. (I'll have to investigate a bit to see if my development environment will let me specify such a configuration).
DonS
Franktown, CO
Did you try installing .NET 3.5 while WM6.5 was flashed in? That might work, if WM/.NET(CF) behave like non-mobile versions (i.e. I can install old versions of .NET on new versions of Windows).
Astrak
Mesa, AZ
Yep that's what I did and it worked, just running through some things on the ROM to see if anything was 3.7 dependant, but so far so good.
DonS
Franktown, CO
Ah, OK. I though't you'd gone back to a previous version of WM (your "reverted the ROM" part threw me).
If it behaves like non-mobile versions, you should have both 3.5 and 3.7 versions of .NET installed now. (Presuming you started with a WM6.5 / .NET 3.7 ROM, then installed a downloaded version of .NET 3.5).
Astrak
Mesa, AZ
Ok, that makes sense. I'm just enjoying this new TF3d interface, but if I couldn't have WIN500 on the phone I'd have to go back to a different ROM.
