Win96 Help Please
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Settings Tab, bottom center, check Extended Frequencies box.
Each new file will need to be rechecked prior to uploading.
Edit: Your request was for tables, not freqs.
The Help file has a good explanation which includes a dialog example.
Edit again:
I just now used Web import and it reported each of the offset and spacing to be in reverse. Click ok on each of these error reports and then select your freq and ID's to import and Win96 will properly corrected the errors.
Eospro
Central Coast NSW
I don't know what numbers eg base freq, offset etc to put in there.
I know i need to enter three sets for the NSW GRN, but i don't know what they are. Sorry if my question was misleading.
Brad
fmon
Eclipse, Virginia
Mine uploaded with these settings
Code:
CH Lo    CH Hi    Base Freq    Offset    Spacing
380      722      415.57500    380       12.5
723      747      413.10000    723       12.5
748      759      415.00000    748       12.5
Edit: The three freqs above may need to be lowest to higest to match the offsets.
Ignore settings
03
04
05
You might want to submit a correction to the Database page so Win96 will import the system properly with out error reports.
The tables in the Database should be:
Custom Frequency Table
Code:
           1               2            3
Base:      413.1000        415.0000    415.575
Spacing:  12.5            12.5         12.5
Offset:    380             723          748
Eospro
Central Coast NSW
Ok, now we're getting somewhere.I have the pro 96 sitting next to my 780.
Both pick up the GRN & the pro 96 shows the takgroup, but i don't hear anything.. Any ideas whats wrong. I have used the settings fmon listed above in order of base freq lowest to highest whick seems right....
fmon
Eclipse, Virginia
Next
PGM
TRUNK
FUNC + 3 if 3600 baud
or
FUNC + 4 if 9600 baud
Up button to Multi Table then press ENTER
Eospro
Central Coast NSW
Ok, Needed the correct base frequencies for my state and had to enter them in the correct order (lowest first). One thing i found a pain in the butt was that i had to enter them for every bank & every V-Folder. 18 times in all. Thank heavens for back ups, i don't want to have to go through that again. Anyway all works fine now. Thanks for everyones help.
Cheers
Brad
