Win96 multi custom freq tables?
cassidy1190
Belmar, NJ
I have a bit of a dilemma programming my 2096. Using win96 I want to enter the multi custom frequency table required for the system I am monitoring. I am a bit confused with some of the extra information the window asks for. I understand base, spacing, and offset, but what is channel low and channel high? How do I figure out what to enter? Also, if the system only has two frequency ranges, what do I enter for the rest of the tables? (Assuming 0s all across)
Thanks for your help,
Dan
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Assuming you are programming a NJ or Pa. system, you should ask in the appropriate forum (we have one for each state). No doubt someone there can give you the proper lo/hi channel and whatever else you need. 73 Mike
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
i have a bit of a dilemma programming my 2096. Using win96 i want to enter the multi custom frequency table required for the system i am monitoring. I am a bit confused with some of the extra information the window asks for. I understand base, spacing, and offset, but what is channel low and channel high? How do i figure out what to enter? Also, if the system only has two frequency ranges, what do i enter for the rest of the tables? (assuming 0s all across)
thanks for your help,
dan
P25 VHF System.
Code:
 8192 12287 136.00000  8192 2.500
12288 16383 146.00000 12288 2.500
16384 20479 156.00000 16384 2.500
Chech this Wiki page Win96 - The RadioReference Wiki
