win97? importing exporting?
tackman331
Can I import the data form a programmed scanner to win97 on the computer then export to another one? These are the exact same scanners pro97. The cable I have is the one from radio shack.
gmclam
Fair Oaks, CA
Let's not use the terms "import" and "export".... those are actions you use with web sites such as this.
In reality, if all you want to do is program the scanners identically, you don't need software. Just plug a cable between them, and "send" from one to clone it to the other.
Using WIN97, you want to "download from scanner" in to the software. Then "upload to scanner" to program the next one. Make sure the cable drivers are loaded and you have the correct COM port set in WIN97 (you can learn which COM port was assigned from the Device Manager in the Control Panel).
