DonS
This version was released yesterday to fix a reported bug (right-clicking in an unoccupied area of a grid would cause a crash).
Unfortunately, I neglected to remove some test code before building the released version. All RadioReference.com web imports died because of this.
Version 01.09, which fixes this problem, is now available here.
This version, while it works as well as 01.07 (less the right-click bug), is a work in progress. I'm adding RadioReference conventional frequency import. The menus have changed, and you'll see new "Trunked systems" and "Conventional frequencies" items under File -> Web import -> RadioReference.com.
"Trunked systems" brings up the familiar interface.
"Conventional frequencies" brings up a new window, from which you can access this type of data. However, the data will not be imported!!!. This feature also requires a change to the "RR.com XML URL" field - you have to append it with 1.1:
http://www.radioreference.com/apps/xml1.1
(the "Trunked systems" interface will accept either the old URL or the appended 1.1).
-Don
-Don
