Wings Over Houston Air Show 2024
Myles
Houston TX
Friday and Saturday shows are in the books. Here are some frequencies to listen to for the remaining Sunday show starting about 11am and running to about 4:30pm
121.850 MHz Airboss
135.725 MHz backup airboss channel (nothing heard)
123.150 MHz Discrete/PA
139.8125 MHz (FM) Blue Angels ground ops "Bravo"
142.6125 MHz (FM) Blue Angels Comm Cart "Alpha"
237.800 MHz Blue Angels
275.350 MHz Blue Angels
284.250 MHz Blue Angels
305.500 MHz Blue Angels Fat Albert (C-130)
346.500 MHz Blue Angels ground comms
384.550 MHz F-16 Viper Demo PA
HFD Medical Carts were using Y-ICS 9 TG on the TxWARN trunked system and HPD using Y-ICS 13 TG 45325. Use Southeast simulcast site.
451.850 MHz Signature Flight Support FBO
Check here for other frequencies for Ellington Airport:
The air show staff use Motorola commercial radios "show radios" with these frequencies:
Simplex channels are Color Code 5.
1 463.2250 * Operations/Security repeater Color Code 15, Time slot 1, Talk group 1
2 464.1625 Fuel/Oil/Smoke repeater Color Code 9, Time slot 1, Talk Group 2???
3 466.7875 Food/Eagle Squadron/Pilot registration/volunteers TG 3
4 464.1625 * Parking repeater Color Code 9, Time Slot 2, Talk Group 4
5 468.6125 * Gates TG 5
6 466.0625 Waste Ops TG 6
7 466.7800 Pyro TG 7
8 461.0875 Finance TG 8
9 461.1875 Pilot Shuttle/Motor Pool TG 9
10 462.7875 Ground Safety TG 10
11 464.9625 Media TG 11
12 463.2250 * Medical repeater Color Code 15, Time slot 2, Talk group 12
13 468.9375 Water Carts TG 13
There may be some operations on FRS channels that I cannot pick up from the house. I may go near the field tomorrow to check.
Enforcer52
Lake Livingston, TX
Thanks for posting the freqs. Programmed them in and will see what I can hear tomorrow. Although probably only get stuff that's in the air because of my distance.
Will stream it on Proscan RSOIP so I can listen on Proscan Client in another room, and/or for anyone else interested.
lakelivingston.ddns.net
Myles
Houston TX
One change from yesterday. They are using 135.725 MHz for discrete now, changed from 123.150 MHz.
Myles
Houston TX
135.725 was used for PA at one point yesterday and once again today.
Thanks, just saw your post after I made my post. I think they were causing interference with some smaller airport around the area using 123.150 MHz. Good that you already confirmed them using it.
Myles
Houston TX
From that distance, you might only hear the Blue Angels when they get up high enough. Good luck!
Myles
Houston TX
Also heard comms on ISR-2 397.125 MHz.
Found a parking channel that is probably in the show radios.
467.8625 MHz DMR Color code 5 talkgroup 14.
If you are within about 3 miles of the field, you can hear the announcer audio on 87.9 MHz WFM.
One correction to the show radio list I posted earlier.
Fuel-Oil-Smoke uses 467.7625 MHz color code 5 talkgroup 2.
Not sure who if anyone uses 464.1625 MHz Color Code 9 Talkgroup 2 on slot 1 but I think I saw someone key up on it once.
