Hi.
I first became familiar with Winradio back between 1996 up until I bought a WR1550i in 2000. It was advertised to work great as a wide range receiver, but that only holds true if you connect it to a homebrew active antenna array, which I had someone build for me. Overall performance was improved dramatically with the antenna array in the 1550i. I later bought an internal G303 and had the array connected to it to try to do all the things I wanted to do with it with some degree of success.
My first WinRadio product was the WR-1000i. In fact the WinRadio product line is what made me change from Mac to PC, or at least get a PC in addition to the Mac. That was in either 1996 or 1997, not sure which, but it was before Windows 98 was out.
I still run two of the WR-1550’s here at the house, they are good little radios, I also have my original WR-1000i and a WR-3550, and both of those are still used. In their day they (the 1550’s) were quite good, with a capability that was matched by few others on the market, and pretty much nothing else at the price point. But until you get to spending real money broadband all mode radios like that are always a compromise.
Typically at the lower cost points a broadband DC to daylight radio is a good VHF/UHF radio with added HF capability. That is the description of the WR-1000i. By the time the WR-1550 came out they had improved the HF performance, driven by competition from the Icom PC-1000 and later PC-1500. The performance of the WinRadio WR-1550 and the Icom PC-1500 was significantly less good than the Icom R-8500, but they also cost less than one third the price.
TANSTAAFL
The Excelsior is a very good radio, with very good performance across its entire range. But, it is not inexpensive. And if your target is HF, as in Shortwave and such, the Excalibur, either Pro or none-Pro, will do everything the Excelsior will and then some (except the second DDC window).
I am not really sure what you mean by “It was advertised to work great as a wide range receiver, but that only holds true if you connect it to a homebrew active antenna array” when talking about the WR-1550. Of course any radio must be connected to an antenna that works across the frequency range being tuned. I can say for sure I have never had any of my wideband receivers attached to an active antenna, I pretty much detest active antennas.
There is no such thing as a single antenna, active or otherwise, that will work well across the entire frequency range of the WR-1550. Keep what I said in mind, work “well”, you can, naturally, make something that will do something across that range, but not as well as covering that range with multiple antennas. Plugging a paperclip into the BNC connector may well work to receive signals across the entire bandwidth, but only if the signals were very strong.
One efficient antenna that goes from 150 kHz to 1500 MHz, 5 orders of magnitude, is a pipe dream…or the ensuing array of antennas going to a single feedpoint will probably cost many, many, times the price of the radio itself. A very well designed Discone antenna might have a bandwidth of 1:25, say covering 50 to 1250 MHz in a single antenna, but an antenna covering the complete range of something like the WR-1550 would require a bandwidth of 1:10000. The reality is that you have to use different antennas for different portions of spectrum, and that is not driven by the radio, but rather by the frequency range being covered. A half wave resonant antenna at 150 kHz has a length of about 1000 meters, while the same type of antenna at 1500 MHz has a length of about 10 cm.
Now I know that a few readers might look at what I said about Discones above and jump in with a comment like “my Diamond D-130J Discone covers 25 to 1300 MHz, so that is like 1:52 bandwidth, not the 1:25 you quote”. This is true, but this antenna, and several similar antennas, do this as an array. They combine a Discone that is good from maybe 70 to 1250 MHz with a loaded vertical to extend the low frequency range, and they also quote such a bandwidth with a known roll-off in performance at either end of the range.
So, realistically, you need at least 2 antennas to cover the bandwidth of something like the WR-1550. Say a Discone to cover 30 to 1500 MHz, and some kind of MF/HF antenna to cover from 30 MHz down. And even then you will still have less than optimal performance in pretty big chunks of spectrum. Personally I use about a dozen antennas to cover that range of frequencies.
And the G39DDC Excelsior covers 9 kHz to 3500 MHz, a ratio of more than 1:38000. An even more daunting antenna task, if you want efficient coverage across the entire bandwidth. Of course, the smart answer here is to pick your battles. Why try to cover all of that range equally when some portions of it are almost unused? You tailor your antennas to your desired targets and frequency ranges, this gives optimal performance and return.
Regardless, whatever radio a person uses you must use an antenna that covers the desired range. A radio without an antenna is like the biggest, baddest, most kick butt stereo in the world…with no speakers attached. And by the same token you would not use a pair of 3” full range portable radio speakers with a 1200 Watt 7+ channel home theater system, or if you did you would not have any right to complain with the resultant sound quality.
T!
