wintelive and GNU radio python error?
welshevo
hey all followed the install from curlyboy readme file.. and all appears good , however when i try and run the telive GRC 10 ch project it starts to run then python crashes so cant go no further? any suggestions folks???
tango20k
dear friend ,
What OS you are running ,u also did you try to disable some channels that you would not need in grc file .
i disable 6 of them immediately , this reduces the processor burden and to some level improves decoding.
you may also try to use single channel grc and advise.
best of luck
welshevo
Wintelive
morning ... im using windows 7 64bit i havent tried disabling channels yet? but dont think it would make much difference? as ive tried various channel counts in GNU. 10, 4, 1 chs.. the FFT window doesnt even load and python crashes?
