Hello,
My old method for decoding fire tones for the upcoming BC396 tone-out feature.
I record the tones of a local conventional tone-out channel in .wav from ARC250 software (.WAV format) for a day or so. forget real time....
I then play them back from Windows media player into a program called FFT Properties while it is in record mode:
http://www.teemach.com/FFTProp/
Set FFT properties to record about 8 seconds as you have to hit record on FFTP then play on WM. (I actually got it down to about 5 seconds for a 4 sec tone sequence)
Stop WM player after the 2nd tone is finished.
Then I setup and play a loop of the 1st tone in FFTP and activate the program frequencyCounter.exe
http://www.tetrascanner.com/freesoftware.html
Maybe it's just my machine but if you have frequencyCounter.exe running (decoding) while playing the signal into FFTP from WM you get errors galore! Too many things accessing the soundcard at one time. I have to close out of everything and start over. I should also mention you need a full duplex soundcard to make this work.
Any "ticking" in the looped signal will confuse the counter program and I have found that moving the start and end loop points a few ms can solve this. I usually loop as much signal as I can, not just a 250ms slice. If it's a 2 second tone I'm looping 1.8sec or so.
After play it in, note it then go the 2nd frequency and do the same thing.
It takes some juggling but once you get going you can ID a freq pair in 1min
This FFT properties will also let you determine the gap, if any between 2 tone freqs.
I should also mention you need a full duplex soundcard to make this work. You must have good, unclipped recordings and good levels into FFTP (not clipped or overloaded) for FC.exe to work well.
This is not easy folks but the best method I have come up with in my short time playing with it.
New method;
After writing this post I downloaded software called Cooleditpro 2.0 from Adobe.
There is a 21 day free trial.
It is MUCH more accurate than the above combination. Accurate to .01Hz but you may find the frequency of the tones transmitted is slightly off...I was surprised....
Anyhow, just record your tone out audio, play it back with CEP click your cursor on the 1st tone, (you don't have to play it) Open the Analyze menu function and it will display the frequency. Click on the 2nd part of the tone and the you are done!
Dave
