wire vs ferret
mainetrunk
York county Me.
I put an older radio antenna on a flexable bnc, I put the antenna in a peice of military pvc with cap, drilled a hole, attatched 16 guage speaker wire to antenna, set it permanent. The wire and rope ( parachute cord lasso'ed to antenna top-- taped up to not chafe, plus no steel to interfere ) comes thru the top. I just dropped the wire last night, 40 feet to the wooden clothes line.Cord will be a hanger, when i can get up on the roof.Belden cale to bnc to sma to alinco.. Now, the question is--
I am getting mil-air hits real good thru the wire.. My uniden15x has a ferret15 feet above the wires highest point.
Is the wire plus the radio antenna THAT sensitive?
example--238.000 comes in on the alinco, not the uniden--the uniden gets am like crazy--good
trap5858
Doylestown PA & Milton DE
The alinco is a communications receiver and more sensitive than the Uniden. Even though both cover a wide range of frequencies the alinco has a more sensitive front end. The ferret may not be tuned to the mil UHF band. Just my thoughts on it and a little experience using an icom r-20
