Wont load
DJBio
PEI
Tryed to open Proscan and it’s stuck on the ProScan screen saying it’s loading and the other window that ya click ok for like web server and won’t load any more
ProScan
Software Provider
Ontario, Calif.
Can you email me all the files in the ProScan folder so I can try to duplicate the problem.
DJBio
PEI
wont let me send the file and seems once i started using radio feed been having troubles and i cant even get radiofeed to login to te server now
DJBio
PEI
i did a unistall before his reply now its stuck on the screen to buy ok enter key
clicked on enter key and ok and nothing
sallen07
Rochester, NY
With this
Did you click "OK"?
That is normal behavior if you had ProScan configured to talk to a scanner on a particular COM port and for whatever reason (scanner off, scanner USB cable unplugged, USB cable moved to different port) the scanner is not there the next time you start the program. If you click "OK" on the dialog box, ProScan starts and you can reconfigure to a new COM port if necessary.
DJBio
PEI
i got radiofeed working today and i did a update for the computer now it wont connect and proscan wont load and different port
ProScan
Software Provider
Ontario, Calif.
I would stop RadioFeed for now and concentrate just on ProScan.
What type of scanner?
Can you power cycle the scanner. You may have done it earlier but do it again.
Advise on the current problem.
sallen07
Rochester, NY
Did you click on "OK" in the dialog box?
ProScan can't open the com port. You need to click OK then open the "Comm Port" dialog and hit "Auto Detect" to see if the scanner is on a different port.
You said you got RadioFeed working. Do you have two scanners? You can't have both programs connected to the same scanner using the same COM port.
Some scanners won't reconnect after a system reboot until you reboot the scanner, or disconnect and reconnect the USB cable.
DJBio
PEI
i removed radio feed and proscan and did a restart of the system
and the scanner is a Pro-2037
DJBio
PEI
i used the 2037 for a feed i am trying to set up and for proscan i have a bcd996p2
ProScan
Software Provider
Ontario, Calif.
Let's concentrate on ProScan. Work on RadioFeed once ProScan issues are resolved.
