Hard cases for this scanner available now on Scanner Master!!
hence "Scanner Master"pricy
Yes they do.do they have one for the 396??? yeah scanner master seems to be pretty pricey
Does the Nylon case for the HP-1 have any method to attach Velcro to the back to allow sticking it to a vertical Velcro surface? Or, in other words, does Velcro sticky back stick to Nylon?Don't be afraid to get the Nylon cases for the ...... the HP-1. I already have the HP-1 nylon case for close to 2 years and a great deal at about $25. To me its better padded than a leather case and not slippery like Leather. .............,.
The type of nylon it is allows Velcro to cling to it but not stick to the point I would trust it. The Hp-1 case has an attached metal clip on the back for your belt on a panel that's riveted to the case. Maybe attach it with some Velcro straps around it but I hesitate attaching anything expensive to a vertical Velcro surface without some type of backup strap or cableDoes the Nylon case for the HP-1 have any method to attach Velcro to the back to allow sticking it to a vertical Velcro surface? Or, in other words, does Velcro sticky back stick to Nylon?
Thanks!
Hey get some pictures up of that new case if ya can.Yes a little pricey but the hard leather case certainly will protect the scanner...sure the soft case for the PRO-106 did it's job until this one came out...it fits perfectly and you can get at the ports too...only negative is no hole for the LED....well a leather punch will fix that!
